Proprietary Traps
The following tables describe proprietary traps for the switch. All of the following traps have a status of current.
Table 1. 1.3.6.1.4.1.45.5.17.0.xx series
OID
Notification type
Objects
Description
1.3.6.1.4.1.45.5.17.0.1
bsDhcpSnoopingBindingTableFull
bsDhcpSnoopingNotificationClientMACAddr
A bsDhcpSnoopingBindingTableFull notification is generated when you try adding a new DHCP binding entry, and the binding table is full. The value of bsDhcpSnoopingNotificationClientMACAddr gives the MAC address that cannot be added to the binding table. This notification also indicates that additional untrusted DHCP packets will not be added to the binding table, and will be dropped.
1.3.6.1.4.1.45.5.17.0.2
bsDhcpSnoopingTrap
  • bsDhcpSnoopingNotificationSourcePort
  • bsDhcpSnoopingNotificationMsgTypebsDhcpSnoopingNotificationSourceMACAddr
  • bsDhcpSnoopingNotificationClientMACAddr
  • bsDhcpSnoopingIfTrusted
A bsDhcpSnoopingTrap notification is generated when a DHCP packet is dropped.
1.3.6.1.4.1.45.5.17.0.4
bsDhcpSnoopingStaticEntryMACConflict
bsDhcpSnoopingNotificationSourceMACAddr bsDhcpSnoopingIfIndex
A bsDhcpSnoopingStaticEntryMACConflict notification is generated when a DHCP packet is dropped, because a static entry with the same MAC address was found in the binding table.
Table 2. 1.3.6.1.4.1.45.5.18.0.xx series
OID
Notification type
Objects
Description
1.3.6.1.4.1.45.5.18.0.1
bsaiArpPacketDroppedOnUntrustedPort
  • bsArpInspectionIfTrusted
  • bsArpInspectionNotificationSourceMACAddr
A bsaiArpPacketDroppedOnUntrustedPort trap signifies that an ARP packet is dropped on an untrusted port, due to an invalid IP or MAC address binding. The port is identified by the instance of bsArpInspectionIfTrusted generated by the trap.
Table 3. 1.3.6.1.4.1.45.5.20.0.xx series
OID
Notification type
Objects
Description
1.3.6.1.4.1.45.5.20.0.2
bsSourceGuardCannotEnablePort
bsSourceGuardConfigMode
A bsSourceGuardCannotEnablePort trap signifies that there are insufficient resources to enable IP Source Guard checking on a port because of internal state changes within the system such as system initialization. The port is identified by the instance of bsSourceGuardConfigMode generated by the trap.
1.3.6.1.4.1.45.5.20.0.1
bsSourceGuardReachedMaxIpEntries
A bsSourceGuardReachedMaxIpEntries trap signifies that the maximum number of IP address entries on a port has been reached. The port is identified by the instance of bssourceGuardConfigMode generated by the trap.
Table 4. 1.3.6.1.4.1.45.5.34.0.xx series
OID
Notification type
Objects
Description
1.3.6.1.4.1.45.5.34.0.1
bsnesGloballyEnabled
A bsnesGloballyEnabled trap signifies that the Energy Saver feature was enabled globally.
1.3.6.1.4.1.45.5.34.0.2
bsnesGloballyDisabled
A bsnesGloballyDisabled trap signifies that the Energy Saver feature was disabled globally.
1.3.6.1.4.1.45.5.34.0.3
bsnesManuallyActivated
A bsnesManuallyActivated trap signifies that the Energy Saver was activated manually.
1.3.6.1.4.1.45.5.34.0.4
bsnesManuallyDeactivated
A bsnesManuallyDeactivated trap signifies that the Energy Saver feature was deactivated manually.
1.3.6.1.4.1.45.5.34.0.5
bsnesScheduleNotApplied
A bsnesScheduleNotApplied trap signifies that a schedule was not applied because SNTP is not synchronized.
1.3.6.1.4.1.45.5.34.0.6
bsnesScheduleApplied
A bsnesScheduleApplied trap signifies that SNTP is synchronized and the schedule is being applied.
1.3.6.1.4.1.45.5.34.0.7
bsnesActivated
A bsnesActivated trap signifies that the Energy Saver feature was activated by the schedule.
1.3.6.1.4.1.45.5.34.0.8
bsnesDeactivated
A bsnesDeactivated trap signifies that the Energy Saver feature was deactivated by the schedule.
Table 5. 1.3.6.1.4.1.45.5.43.0.xx series
ODID
Notification type
Objects
Description
1.3.6.1.4.1.45.5.43.0.1
bsLstInterfaceStatusChanged
  • ifIndex
  • bsLstInterfaceStatus
  • bsLstGroupIndex
A bsLstInterfaceStatusChanged trap signifies that a physical or logical interface changed status in a Link-state tracking (LST) tracking group.
1.3.6.1.4.1.45.5.43.0.2
bsLstInterfaceOperStateChanged
  • ifIndex
  • bsLstGroupIndex
A bsLstInterfaceOperStateChanged trap signifies that the operational status of an LST group changed due to an interface status change. For example, when the last interface in an LST group is down, the operational status of theLST group changes to down.
Table 6. 1.3.6.1.4.1.2272.1.4.10.1.1.xxx series
OID
Notification type
Objects
Description
1.3.6.1.4.1.2272.1.4.10.1.1.114
rcPortShutdownReason
  • rcPortVLacpTotalFlapCount
  • rcPortVLacpFirstFlapTimeStamp
  • rcPortVLacpLastFlapTimeStamp
An rcPortShutdownReason trap signifies that the specific VLACP link port status is down as VLACP flaps are detected on that port.
Table 7. 1.3.6.1.4.1.2272.1.21.0.xx series
OID
Notification type
Objects
Description
1.3.6.1.4.1.2272.1.21.0.3
rcnErrorNotification
rcErrorLevel rcErrorCode rcErrorText
An rcnErrorNotification trap signifies that the SNMPv2 entity, acting in an agent role, has detected an error condition.
1.3.6.1.4.1.2272.1.21.0.4
rcnStpNewRoot
rcStgId
An rcnStpNewRoot trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Spanning Tree Protocol declared the device to be the new root of the spanning tree.
1.3.6.1.4.1.2272.1.21.0.5
rcnStpTopologyChange
rcStgId rcPortIndex
An rcnStpTopologyChange trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Spanning Tree Protocol has gone due to a topology change event.
1.3.6.1.4.1.2272.1.21.0.6
rcnChasPowerSupplyDown
  • rcChasPowerSupplyId
  • rcChasPowerSupplyOperStatus
An rcnChasPowerSupplyDown trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the rcChasPowerSupplyOperStatus object for one of its power supply units is about to transition into the down state.
1.3.6.1.4.1.2272.1.21.0.7
rcnChasFanDown
  • rcChasFanId
  • rcChasFanOperStatus
An rcnChasFanDown trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the rcChasFanOperStatus object for one of its power supply units is about to transition into the down state.
1.3.6.1.4.1.2272.1.21.0.8
rcnLinkOscillation
rcPortIndex
An rcnLinkOscillation trap signifies that the SNMPv2 entity, acting in an agent role, has detected an excessive number of link state transitions on the specified port.
1.3.6.1.4.1.2272.1.21.0.9
rcnMacViolation
  • rcErrorText
  • rcPortIndex
An rcnMacViolation trap signifies that the SNMPv2 entity, acting in an agent role, has received a PDU with an invalid source MAC address.
1.3.6.1.4.1.2272.1.21.0.13
rcn2kTemperature
rc2kChassisTemperature
An rcn2kTemperature trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the chassis is overheating.
1.3.6.1.4.1.2272.1.21.0.14
rcnChasPowerSupplyUp
An rcnChasPowerSupplyUp trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the rcChasPowerSupplyOperStatus object for one of its power supply units is about to transition into the up state.
1.3.6.1.4.1.2272.1.21.0.16
rcnStpTCN
  • rcStgId
  • rcPortIndex
  • rcStgBridgeAddress
An rcnStpTCN trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Spanning Tree Protocol has gone due to a topology change event.
1.3.6.1.4.1.2272.1.21.0.17
rcnSmltIstLink Up
An rcnSmltIstLinkUp trap signifies that the split MLT link is from down to up.
1.3.6.1.4.1.2272.1.21.0.18
rcnSmltIstLink Down
rcnSmltIstLinkDown
An rcnSmltIstLinkDown trap signifies that the split MLT link is from up to down.
1.3.6.1.4.1.2272.1.21.0.19
rcnSmltLinkUp
rcMltSmltId
An rcnSmltLinkUp trap signifies that the split SMLT link is up.
1.3.6.1.4.1.2272.1.21.0.20
rcnSmltLinkDo wn
rcMltSmltId
An rcnSmltLinkDown trap signifies that the split SMLT link is down.
1.3.6.1.4.1.2272.1.21.0.21
rcnChasFanUp
  • rcChasFanId
An rcnChasFanUp trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the rcChasFanOperStatus object for one of its power supply units is about to transition into the up state.
1.3.6.1.4.1.2272.1.21.0.22
rcnPasswordChange
  • rcCliPasswordChange
  • rcCliPassChangeResult
An rcnPasswordChange trap signifies that the SNMPv2 entity, acting in an agent role, has detected that one of the CLI passwords is changed.
1.3.6.1.4.1.2272.1.21.0.23
rcnEmError
  • rc2kCardIndex
  • rcChasEmModeError
An rcnEmError trap signifies that the SNMPv2 entity, acting in an agent role, has detected an Em error.
1.3.6.1.4.1.2272.1.21.0.26
rcnSmartCpldTimerFired
rc2kCardIndex
An rcnSmartCpldTimerFired trap signifies that the CP ID timer fired.
1.3.6.1.4.1.2272.1.21.0.27
rcnCardCpldNotUpDate
rc2kCardIndex
An rcnCardCpldNotUpDate trap signifies that the CP ID is not up-to-date.
1.3.6.1.4.1.2272.1.21.0.28
rcnIgapLogFileFull
An rcnIgapLogFileFull trap signifies that the IGAP accounting time-out Log File has reached the maximum.
1.3.6.1.4.1.2272.1.21.0.30
rcnSshServerEnabled
rcSshGlobalPort
An rcnSshServerEnabled trap signifies that the SSH server is enabled.
1.3.6.1.4.1.2272.1.21.0.31
rcnSshServerDisabled
rcSshGlobalPort
An rcnSshServerDisabled trap signifies that the SSH server is disabled.
1.3.6.1.4.1.2272.1.21.0.37
rcnSaveConfigAction
rcSysActionL1
An rcnSaveConfigAction trap indicates that the switch run time or boot configuration is being saved.
1.3.6.1.4.1.2272.1.21.0.38
Note:
This trap does not apply to all platforms.
rcnLoopDetectOnPort
  • rcVlanId
  • rcPortIndex
An rcnLoopDetectOnPort trap indicates that a loop has been detected on a port. The VLAN on that port will be disabled.
1.3.6.1.4.1.2272.1.21.0.41
rcnAggLinkUp
rcMltId
An rcnAggLinkUp trap is generated when the operational state of the aggregator changes from down to up.
1.3.6.1.4.1.2272.1.21.0.42
rcnAggLinkDown
rcMltId
An rcnAggLinkDown trap is generated when the operational state of the aggregator changes from up to down.
1.3.6.1.4.1.2272.1.21.0.59
rcnFdbProtectViolation
  • rcVlanId
  • rcPortIndex
The rcnFdbProtectViolation trap signifies that the port has violated the user-configured limit for total number of fdb-entries learned on that port.
1.3.6.1.4.1.2272.1.21.0.60
rcnLogMsgControl
  • rcSysMsgLogFrequency
  • rcSysMsgLogText
An rcnLogMsgControl trap signifies whether the number of times of repetition of the particular Log message has exceeded the particular frequency or count.
1.3.6.1.4.1.2272.1.21.0.61
rcnSaveConfigFile
  • rcSysActionL1
  • rcSysConfigFileName
An rcnSaveConfig trap signifies that either the runtime config or the boot config has been saved on the switch.
1.3.6.1.4.1.2272.1.21.0.62
rcnDNSRequestResponse
  • rcSysDnsServerListIpAddr
  • rcSysDnsRequestType
An rcnDnsRequestResponse trap signifies that the switch sent a query to the DNS server or that it received a successful response from the DNS Server.
1.3.6.1.4.1.2272.1.21.0.63
rcnDuplicateIpAddress
  • ipNetToMediaNetAddress
  • ipNetToMediaPhysAddress
An rcnDuplicateIpAddress trap signifies that a duplicate IP address is detected on the subnet.
1.3.6.1.4.1.2272.1.21.0.64
rcnLoopDetectPortDown
  • rcPortIndex
  • ifAdminStatus
  • ifOperStatus
An rcnLoopDetectPortDown trap signifies that a loop has been detected on a port and the port is going to shut down.
1.3.6.1.4.1.2272.1.21.0.67
rcnLoopDetectMacDiscard
  • rcPortIndex
  • rcSysMacFlapLimitTime
  • rcSysMacFlapLimitCount
An rcnLoopDetectMacDiscard trap signifies that a loop has been detected on a port and the MAC address will be discarded on all ports in that VLAN.
1.3.6.1.4.1.2272.1.21.0.68
rcnAutoRecoverPort
rcPortIndex
An rcnAutoRecoverPort trap signifies that autorecovery has reenabled a port that was previously disabled by link flap.
1.3.6.1.4.1.2272.1.21.0.69
rcnAutoRecoverLoopDetectedPort
rcVlanNewLoopDetectedAction
An rcnAutoRecoverPort trap signifies that autorecovery has cleared the loop detect action that was taken on a port.
1.3.6.1.4.1.2272.1.21.0.74
rcnTacacsAuthFailure
rcTacacsGlobalLastUserName
An rcnTacacsAuthFailure trap signifies that TACACS+ authentication failed for a user.
1.3.6.1.4.1.2272.1.21.0.75
rcnTacacsNoServers
An rcnTacacsNoServers trap signifies that you are unable to use any TACACS+ servers for authentication.
1.3.6.1.4.1.2272.1.21.0.76
rcnTacacsRxUnsupportedFrame
  • rcTacacsGlobalLastAddressType
An rcnTacacsRxUnsupportedFrame trap signifies that an unsupported frame was received from the TACACS+ server.
1.3.6.1.4.1.2272.1.21.0.77
rcnTacacsExceededMaxLogins
An rcnTacacsExceededMaxLogins trap signifies that there was an attempt to exceed the maximum number of allowed TACACS+ logins.
1.3.6.1.4.1.2272.1.21.0.78
rcnTacacsClientFailure
An rcnTacacsClientFailure trap signifies that the TACACS+ Client application is down.
1.3.6.1.4.1.2272.1.21.0.80
rcnVlacpPortDown
rcPortIndex
An rcnVlacpPortDown trap signifies that VLACP is down on the port specified.
1.3.6.1.4.1.2272.1.21.0.81
rcnVlacpPortUp
rcPortIndex
An rcnVlacpPortUp trap signifies that VLACP is up on the port specified.
1.3.6.1.4.1.2272.1.21.0.83
rcnEapMacIntrusion
  • rcSysIpAddr
  • rcRadiusPaePortNumber
  • rcRadiusEapLastAuthMac
  • rcRadiusEapLastRejMac
An rcnEapMacIntrusion trap signifies that an EAP MAC intrusion has occurred on this port.
1.3.6.1.4.1.2272.1.21.0.110
rcnMaxRouteWarnClear
rcVrfName
An rcnMaxRouteWarnClear trap signifies that the number of routes in the routing table of the virtual router has dropped below the warning threshold.
1.3.6.1.4.1.2272.1.21.0.111
rcnMaxRouteWarnSet
rcVrfName
An rcnMaxRouteWarnSet trap signifies that the routing table for the virtual router is reaching its maximum size. Take action to prevent this.
1.3.6.1.4.1.2272.1.21.0.112
rcnMaxRouteDropClear
rcVrfName
An rcnMaxRouteDropClear trap signifies that the routing table for the virtual router is no longer dropping new routes as it is below the maximum size.
1.3.6.1.4.1.2272.1.21.0.113
rcnMaxRouteDropSet
rcVrfName
An rcnMaxRouteDropSet trap signifies that the routing table for the virtual router has reached the maximum size, and is now dropping all new nonstatic routes.
1.3.6.1.4.1.2272.1.21.0.117
rcnMstpNewCistRoot
rcStgBridgeAddress
An rcnMstpNewCistRoot trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Multiple Spanning Tree Protocol has declared the device to be the new root of the common internal spanning tree.
1.3.6.1.4.1.2272.1.21.0.118
rcnMstpNewMstiRoot
  • rcStgId
An rcnMstpNewMstiRoot trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Multiple Spanning Tree Protocol has declared the device to be the new root of the spanning tree instance.
1.3.6.1.4.1.2272.1.21.0.119
rcnMstpNewCistRegionalRoot
rcStgBridgeAddress
An rcnMstpNewCistRegionalRoot trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Multiple Spanning Tree Protocol has declared the device to be the new regional root of the common internal spanning tree.
1.3.6.1.4.1.2272.1.21.0.120
rcnRstpNewRoot
rcStgBridgeAddress
An rcnRstpNewRoot trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Rapid Spanning Tree Protocol has declared the device to be the new root of the spanning tree.
1.3.6.1.4.1.2272.1.21.0.124
rcnRsmltEdge PeerModified
rcVlanId
An rcnRsmltEdgePeerModified trap signifies that the RSMLT peer address is different from that of the stored address. You must save the configuration if EdgeSupport has to use this information on the next restart.
1.3.6.1.4.1.2272.1.21.0.143
rcn2kGbicRemoved
  • rc2kCardIndex
  • rcPortIndex
  • rcPortUserLabel1
  • rcPortUserLabel2
  • rc2kChassisUserLabel1
An rcGbicRemoved trap signifies that the SNMPv2 entity, acting in an agent role has detected that an XFP or SFP is removed from the specified slot or port.
1.3.6.1.4.1.2272.1.21.0.144
rcn2kGbicInserted
  • rc2kCardIndex
  • rcPortIndex
  • rcPortUserLabel1
  • rcPortUserLabel2
An rcGbicInserted trap signifies that the SNMPv2 entity, acting in an agent role has detected that the an XFP or SFP is inserted in the specified slot or port.
1.3.6.1.4.1.2272.1.21.0.167
rcnChasPowerSupplyNoRedundancy
An rcnChasPowerSupplyNoRedundancy trap signifies that the chassis is running on a power supply without redundancy.
1.3.6.1.4.1.2272.1.21.0.168
rcnChasPowerSupplyRedundancy
An rcnChasPowerSupplyRedundancy trap signifies that the chassis is running on a power supply with redundancy.
1.3.6.1.4.1.2272.1.21.0.171
rcnLicenseTrialPeriodExpired
An rcnLicenseTrialPeriodExpired trap signifies that the Trial Period License has expired.
1.3.6.1.4.1.2272.1.21.0.172
rcnLicenseTrialPeriodExpiry
rcSysLicenseTrialDaysLeft
An rcnLicenseTrialPeriodExpiry trap signifies the time remaining, in days, before the Trial Period License expires.
1.3.6.1.4.1.2272.1.21.0.173
rcnVrfUp
rcVrfName rcVrfOperStatus
This notification is generated when the operational status of the specified VRF is toggled from down to up.
1.3.6.1.4.1.2272.1.21.0.174
rcnVrfDown
This notification is generated when the operational status of the specified VRF is toggled from up to down.
1.3.6.1.4.1.2272.1.21.0.175
rcnMrouteIngressThresholdExceeded
  • rcIpResourceUsageGlobalIngressRecInUse
  • rcIpResourceUsageGlobalIngressThreshold
This notification is generated when the number of mroute ingress records exceeds the ingress threshold.
1.3.6.1.4.1.2272.1.21.0.176
rcnMrouteEgressThresholdExceeded
This notification is generated when the number of mroute egress records exceeds the egress threshold.
1.3.6.1.4.1.2272.1.21.0.185
rcnChasPowerSupplyRunningLow
An rcnChasPowerSupplyRunningLow trap signifies that the chassis is running on low power supply.
1.3.6.1.4.1.2272.1.21.0.192
rcnIsisPlsbMetricMismatchTrap
  • rcIsisLocalLspId
  • rcIsisLocalL1Metric
  • rcIsisNgbLspId
  • rcIsisNgbL1Metric
  • rcIsisPlsbTrapType
  • rcIsisTrapIndicator
  • rcIsisLocalHostName
  • rcIsisNgbHostName
An rcnIsisPlsbMetricMismatchTrap signifies that a Link State Packet (LSP) with a different value of Level 1 metric is received.
1.3.6.1.4.1.2272.1.21.0.193
rcnIsisPlsbDuplicateSysidTrap
  • rcIsisLocalSysId
  • rcIsisLocalInterface
An rcnIsisPlsbduplicateSysidTrap signifies that a Hello packet with a duplicate system ID is received.
1.3.6.1.4.1.2272.1.21.0.194
rcnIsisPlsbLsdbUpdateTrap
rcIsisPlsbTrapType
An rcnIsisPlsbLsdbUpdateTrap signifies that link state database (LSDB) information has changed.
1.3.6.1.4.1.2272.1.21.0.196
rcnChasFanCoolingLow
  • rcChasFanType
  • rcErrorLevel
  • rcErrorText
An rcnaChasFanCoolingLow trap signifies that the chassis is running on low fan cooling.
1.3.6.1.4.1.2272.1.21.0.278
rcnIsisPlsbBvidMismatchTrap
  • rcIsisLocalSysId
  • rcIsisLocalPrimaryBvid
  • rcIsisLocalPrimaryTieBrkAlg
  • rcIsisLocalSecondaryBvid
  • rcLocalSecondaryTieBrkAlg
  • rcIsisNgbSysId
  • rcIsisNgbPrimaryBvid
  • rcIsisNgbPrimaryTieBrkAlg
  • rcIsisNgbSecondaryBvid
  • rcIsisNgbSecondaryTieBrkAlg
  • rcIsisLocalBvidCounter
  • rcIsisNgbBvidCounter
  • rcIsisNgbHostName
An rcnIsisPlsbBvidMismatchTrap signifies when a backbone VLAN ID (BVID) Type-Length-Value (TLV) from a neighbor node does not match the local configuration.
1.3.6.1.4.1.2272.1.21.0.279
rcnIsisPlsbSmlt VirtBmacMism atchTrap
  • rcIsisLocalVirtualBmac
  • rcIsisPeerVirtualBmac
An rcnIsisPlsbSmltVirtBmacMis matchTrap signifies that the virtual Backbone MAC (BMAC) configured in the switch is different from the virtual BMAC configured on the interswitch trunking (IST) peer.
1.3.6.1.4.1.2272.1.21.0.280
rcnIsisPlsbSmlt PeerBmacMis matchTrap
  • rcIsisSysId
  • rcIsisSmltPeerSysId
An rcnIsisPlsbSmltPeerBmacMis matchTrap signifies one of the following situations:
  • The Split MultiLink Trunking (SMLT) peer Backbone MAC (BMAC) configured in the interswitch trunking (IST) peer is different from the Intermediate-System-to- Intermediate-System (IS-IS) System ID of the local switch.
  • The SMLT peer BMAC configured on the local switch is different from the IS-IS System ID of the IST peer.
1.3.6.1.4.1.2272.1.21.0.281
rcnIsisPlsbAdjStateTrap
  • rcIsisNgbSysId
  • rcIsisAdjState
  • rcIsisNgbHostName
An rcnIsisPlsbAdjStateTrap signifies when IS-IS adjacency state changes.
1.3.6.1.4.1.2272.1.21.0.282
rcnIsisPlsbDuplicateNNameTrap
  • rcIsisNgbNickname
  • rcIsisNgbSysId
  • rcIsisDuplicateNnameCounter
  • rcIsisNgbHostName
An rcnIsisPlsbDuplicateNNameTrap signifies that a Link State Packet (LSP) with a duplicate nickname is received. The trap should be generated by all the switches in the network.
1.3.6.1.4.1.2272.1.21.0.283
rcnIsisPlsbSmlt SplitBebMisma tchTrap
  • rcIsisLocalSmltSplitBeb
  • rcIsisPeerSmltSplitBeb
An rcnIsisPlsbSmltSplitBebMism atchTrap signifies that the SMLT Split Backbone Edge Bridge (BEB) configured on the local switch and on the IST peer are the same. One IST switch must be configured as the primary Split BEB and the other IST peer must be configured as the secondary Split BEB.
1.3.6.1.4.1.2272.1.21.0.284
rcnIsisPlsbMultiLinkAdjTrap
  • rcIsisNgbSysId
  • rcIsisPrevInterface
  • rcIsisNgbHostName
An rcnIsisPlsbMultiLinkAdjTrap signifies when the Intermediate-System-to-Intermediate-System (IS-IS) protocol forms more than one adjacency with the same IS-IS.
1.3.6.1.4.1.2272.1.21.0.285
rcnaSshSessionLogout
rcSshGlobalHostIpAddr
An rcnaSshSessionLogout trap signifies a Secure Shell (SSH) session logout.
1.3.6.1.4.1.2272.1.21.0.286
rcnaSshUnauthorizedAccess
An rcnaSshUnauthorizedAccess trap signifies that unauthorized access has occurred. It is deprecated by rcnaSshUnauthorizedAccess.
1.3.6.1.4.1.2272.1.21.0.287
rcnaAuthenticationSuccess
  • rcLoginUserName
  • rcLoginHostIpAddress
An rcnaAuthenticationSuccess trap signifies that a login is successful. The Trap includes the login username and the host IP address. It is deprecated by rcnaAuthenticationSuccess.
1.3.6.1.4.1.2272.1.21.0.288
rcnaSshSessionLogin
An rcnaSshSessionLogin trap signifies that there is a Secure Shell (SSH) session login.
1.3.6.1.4.1.2272.1.21.0.305
RcIsisPlsbSmltVirtBmacMisconfigTrap
  • rcIsisSmltVirtBmacMisconfigNodeSysId
  • rcIsisSmltVirtBmacMisconfigNodeHostName
An SPBM ISIS trap signifies that SMLT virtual BMAC has been used by nodes other than the SMLT nodes as system-id or MAC.
1.3.6.1.4.1.2272.1.21.0.306
Note:
rcnPortChannelizedStateChangeTrap
  • rcPortIndex
  • rcChannelizedPortAdminMode
An rcnPortChannelizedStateChangeTrap notification signifies that a port channelized state has changed by administratively enabling or disabling.
1.3.6.1.4.1.2272.1.21.0.335
rcnSystemUsbInternalAccessErrorTrap
An rcnSystemUsbInternalAccessErrorTrap notification signifies that the system has lost internal access to the USB. This trap only applies to platforms that require the USB as part of the operating system.
1.3.6.1.4.1.2272.1.21.0.341
rcnDvrVistPeerDomainMismatchErrorTrap
An rcnDvrVistPeerDomainMismatchErrorTrap notification is generated when the VIST link comes up between two DvR peers that are in different DvR domains.
1.3.6.1.4.1.2272.1.21.0.342
rcnDvrVistPeerDomainMismatchErrorClearTrap
An rcnDvrVistPeerDomainMismatchErrorTrap notification is generated when the error condition of having a VIST link up between two DvR peers from different DvR domains is cleared.
1.3.6.1.4.1.2272.1.21.0.351
rcnIsisPlsbIsisEnabledWithZeroNicknameTrap
  • rcIsisLocalSysId
An rcnIsisPlsbIsisEnabledWithZeroNicknameTrap notification is generated when the IS-IS is enabled with a zero nickname.
1.3.6.1.4.1.2272.1.21.0.352
rcnRestConfServerOperationStatusTrap
An rcnRestConfServerOperationStatusTrap notification is generated when the RESTCONF server is enabled or disabled to indicate the operational status of the RESTCONF server.
Table 8. 1.3.6.1.4.1.2272.1.206.x.x.x series
OID
Notification type
Objects
Description
1.3.6.1.4.1.2272.1.206.1.0.1
rcVrrpTmpTrapNewMaster
  • rcVrrpTmpOperationsMasterIpAddr
  • rcVrrpTmpNewMasterReason
This notification is generated when Virtual Router Redundancy Protocol (VRRP) transitions to the master.
1.3.6.1.4.1.2272.1.206.2.2.1
rcVrrpExtTrapStateTransition
  • ifIndex
  • rcVrrpExtTrapStateTransitionType rcVrrpExtTrapStateTransitionCause
  • rcVrrpExtOperationsVrId
  • rcVrrpTmpOperationsPrimaryIpAddr
This notification is generated when a transition happens in the state of Virtual Router Redundancy Protocol (VRRP), for instance, a transition from master to backup when shutdown is received.
